Activity Forums Maxon Cinema 4D How to exclude spesific objects from enviromental fog?
  • How to exclude spesific objects from enviromental fog?
    Posted by Rodrigo Diaz on July 13, 2009 at 9:31 pm
    Hello
    I need enviromental fog in a landscape scene. The problem is that the sun becomes either to bright or invisible dependent on the viewers distanse to the sun. I cant make the fog less dense because its crusial for the scene. I think I need either to exclude the sun from the effects of the fog, or limit the fog “area”.
    Does anyone know how to accomplish this, or have a better idea?
    Rodrigo Diaz replied 17 years, 1 month ago 1 Member · 1 Reply
  • Rodrigo Diaz
    July 13, 2009 at 10:08 pm
    Ok, problem solved.
    I uncheck the affect background in the enviroment options(of course). Put in a premade sky object and turned on the sun.
    Now I only need the lens effect on the sky-sun….?
    Or is this done in the render settings?
