Activity Forums Storage & Archiving How to establish the serial connection with raid controller Options ?
  • How to establish the serial connection with raid controller Options ?
    Posted by Irrani Dam on November 20, 2009 at 1:14 am
    I want to make changes in configuration settings on raid controller
    which connected to storage controller(Stonefly). It has some problem
    in performance we need to sort out it and rectify can anyone help me
    how to establish the serial connection with raid controller? or is
    their is any settings to be made in SC to access raid controller
    console.
    thanks…
    Irrani
    Edwards Willeam replied 16 years, 9 months ago 2 Members · 1 Reply
  • Edwards Willeam
    November 21, 2009 at 1:35 am
    Here are some tips.
    Configuring RS-232 Connection via Front Panel
    Take the following steps to change the baud rate using the front
    panel:
    Press ENT for two seconds to enter the Main Menu. Press t or s to
    select “View and Edit Configuration ..”, then press
    ENT.
    Select “Communication Parameters ..”, then press ENT.
    Select “RS-232 Configuration ..”, then press ENT.
    Select “COM1 Configuration ..”, then press ENT.
    Select “Baud-rate 38400 ..”, then press ENT.
    If other baud rate is preferred, press t or s to select the baud
    rate,
    then press ENT for 2 seconds to confirm the selected baud
    rate. Set identical baud rate to your controller and your host
    computer
    Starting RS-232 Terminal Emulation
    The keys used when operating via the terminal are as follows:
    To select options
    [Enter] To go to a submenu or to execute a selected option
    [Esc] To escape and go back to the previous menu
    [Ctrl] [L] The controller will refresh the screen information
    Kind regards,
    Edwards
