Activity Forums Apple Final Cut Pro Legacy How to emulate cool “8mm-lightwash” effect in FCP?…
  • How to emulate cool “8mm-lightwash” effect in FCP?…
    Posted by Earl Smith on September 7, 2008 at 8:13 am
    I’ve been searching for a good amount on how to emulate the light/lens-flare effect seen in this rollerblading video trailer at :20, :23-:24 seconds.
    https://www.youtube.com/watch?v=czKfwB4vmRM
    I have Final Cut Pro and was wondering if anybody has any ideas to any plugins or methods that can generate a similar effect?
    Any help would be much appreciated.
    thanks
    Andy Wicks replied 16 years, 10 months ago 5 Members · 4 Replies
  • Joel Peregrine
    September 7, 2008 at 1:45 pm
    Hi Earl,
    Artbeats Film Clutter 1 and 2 is an option, though its pricey. Place the Artbeats clip on the track above where you want the effect and change it’s composite mode to screen.
    https://www.artbeats.com/collections/403
    The MovieFX transition from this group also comes in handy:
    https://www.cgm-online.com/eiperle/cgm_e.html#dve2
  • Lars Fuchs
    September 8, 2008 at 2:43 pm
    Well, if you haven’t already shot your footage, you could just shoot 8mm film. You can still get film, processing, and quality transfers for regular 8. ( see Onsuper8.org for lots of good links). Typically the flares come from the ends of the daylight rolls which are exposed when the camera is opened. (if you want to use super 8, which is easier to come by, you can flash the cartridge in a couple of places to try and duplicate the effect. Its tougher with super 8 because of the cartridge.) A spring wound 16mm camera might give you the best results.
    Or you could buy some stock fooage. Here are two that came up in my first quick-and-dirty search:
    https://www.pond5.com/stock-footage/114977/film-flash-4.html or
    https://www.pond5.com/stock-footage/114973/16mm-film-flash-1.html
    and I’m sure iStockphoto and the other online stock houses have similar stuff. As previously mentioned in the thread, just put them in a higher video track and set comp mode to screen. You might also want to add some subtle (or not so subtle) speed ramps around the flashes.
  • Kevin Monahan
    September 8, 2008 at 4:14 pm
    That video used Art Beats Film Clutter. If you want that look, get Film Clutter.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Andy Wicks
    October 18, 2009 at 9:49 pm
    Hi
    Filmmakers interested in 8mm cine effects might care to check our 8mm Distress Kit:
    https://www.mediapreview.net/8mm.htm
    There’s a demo, tutorial and 3 free samples (and lots of light leaks and flares!)
    Andy Wicks
    mediapreview.net
    Andy Wicks – mediapreview.net
