Activity › Forums › Adobe After Effects › How to edit text preset?
Posted by Dmitry Sokolov on November 21, 2011 at 10:41 amchange the preset
(speed,in,out etc)Angie Taylor replied 14 years, 10 months ago 2 Members · 1 Reply -
1 Reply
Angie Taylor
November 21, 2011 at 1:51 pmHi there,
The best solution for editing Text Presests is to start by selecting the layer and hitting the “U” key to expose keyframes. Then you can just adjust the keyframes to adjust the timing.
For even more control, select the layer and then hit the U key twice (in quick succession) to expose any property that has been adjusted from it’s default setting. this gives you an idea of which properties were adjusted to achieve the effect. Try Brainstorm tool on the selected properties to randomise them and see what they currently add to the mix.
Hope this helps!
cheers,
Angie
Angie Taylor animation & illustration for television, film, web and devices
https://www.angietaylor.co.uk
Twitter: theangietaylor
Linkedin: theangietaylor
https://www.facebook.com/pages/Angie-Taylor/118378194869002
