Activity › Forums › Adobe Illustrator › How to easily create these layered shapes?
Posted by Lucas Schwartz on August 23, 2020 at 12:15 pmhello,
I would like to know how can I easily create layered shapes such as shown in the image below:
Many thanks!
Tom Van damme replied 6 years ago 2 Members · 4 Replies -
Tom Van damme
August 24, 2020 at 7:23 amHi Lucas,
there’s a few steps you’ll need to do to obtain this result, so no fast and easy way ☺
You’ll need to draw a basic shape first – I guess some sort of rounded W stroke with some thickness will do. Then use Object > Path > Offset Path… to create the different layers. Make sure you select “Round joins”. You’ll need to experiment a bit with the offset value to get the desired result.
The created offset will go all around the basic shape so you’ll have to manually cut some parts. Make a copy of the top part, then cut this copy from the underlying part using Pathfinder > Minus Front.Hope this helps ☺
Tom -
Lucas Schwartz
August 26, 2020 at 4:36 pm -
Tom Van damme
August 27, 2020 at 6:50 amThat does seem strange, yes.
It’s probably due to superfluous anchor points. As far as I can see, the part in your picture should be straight, right?
Maybe try to simplify the shapes first before you do create the cutouts. The less anchor points there are, the smoother the end result will be.
You can simplify paths with Object > Path > Simplify… (or Remove Anchor Points and such…)
