Activity › Forums › Adobe After Effects › How to duplicate single frame area of clone tool onto other frames?
Posted by Corey Witherow on November 25, 2012 at 11:50 pmHow can I Roto paint one frame, and than mask a single area of it and duplicate that to other frames?
John Cuevas replied 13 years, 10 months ago 4 Members · 4 Replies -
Axel Arzola
November 26, 2012 at 12:57 amI don’t think I understood the question completely but I usually do the first and the last frame of the roto mask. After that the middle and keep doing it that way because the keyframe will be smart enough to move your mask path or roto brush.
By doing this you save a lot of time and get AE to do some work for you.I hope that helps.
Axel Arzola
https://twitter.com/AxelArzola
https://www.facebook.com/arzolafilm
https://www.linkedin.com/in/axelarzola -
Corey Witherow
November 26, 2012 at 1:03 amLet’s say I paint out a shadow in just one frame on a wall. If I want to copy the painted wall to other frames, what’s a good way to do that? Thanks!
Vishesh Arora
November 26, 2012 at 2:20 amCorey
Can’t say anything precisely without seeing the footage. Can you upload a still image to describe what exactly you want to achieve?
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
John Cuevas
November 26, 2012 at 12:48 pmIf you are using the clone tool(paint effect), select the layer and press “e” to reveal your effects and you should have a paint effect. Twirl that down and there will be a layer for each clone you made. You can move these layers on the timeline to where you want them to start and extend the end points if you need to lengthen the duration.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
