Activity Forums Adobe After Effects how to duplicate comp?
  • how to duplicate comp?
    Posted by Eric Viebe on June 13, 2013 at 10:02 am
    how can i duplicate a composition and change its properties without effecting the first one properties?
    i allways get the same picture twice even if i duplicate the composition from the project window.i must be linked some how to the other comp.
    John Cuevas replied 13 years, 2 months ago 4 Members · 3 Replies
  • Marco Conceicao
    June 13, 2013 at 10:18 am
    Hi Eric.
    1) In the project panel select your composition, 1 left click.
    2) Then, on windows, press CTRL+D. A perfect but independent copy should appear.
    Is it what yoou need?
  • Tielman Dewaele
    June 13, 2013 at 11:41 am
    Duplicate the precomp in the timeline. duplicate the precomp in the project window. rename it. change the properties there. and repclace it(alt+drop) over the duplicated precomp in the timeline.
    Hope then makes sence.
    T
    MacPro/PC
    Production Premum cs 5.5
    FCP 7.0 studio
    C4d R11,5 & R14
  • John Cuevas
    June 13, 2013 at 1:58 pm
    Are you duplicating a precomp in the project window, because after duplicating it, a new version isn’t automatically opened up in the timeline, you will still be working in the original until you open up the new duplicate(a mistake I make often)
    There’s a great script, True Comp Duplicator, that makes complete duplicates of a compe and it’s precomps creating new links, you might want to check it out.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
