Activity Forums Maxon Cinema 4D How to duplicate a material along with an object
  • How to duplicate a material along with an object
    Posted by Fernando Bittar on February 6, 2017 at 4:25 am
    I have a simple rig that has a material assigned to some object down the hierarchy.
    The rig has user data with color parameters that are tied to the material’s color parameters.
    Basically this rig will need to be copied in certain scenes. I want the material to be duplicated too when I copy and paste the object.
    That behavior used to work before: https://vimeo.com/28351230
    But now I can’t seem to replicate that.
    I’m on version R17.
    Any help appreciated.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Brian Jones replied 9 years ago 3 Members · 2 Replies
  • Theodor Kozko
    July 28, 2017 at 9:30 pm
    Hey Fernando,
    I am trying to figure out the same thing, did you have any luck finding a solution?
  • Brian Jones
    July 29, 2017 at 7:10 pm
    if you save an object with ‘Save Object Preset’ then load it (with Load Object Preset) materials will come in duplicated too
