Activity Forums Video Copilot How to download Flash tutorials to hard drive?
  • How to download Flash tutorials to hard drive?
    Posted by Austen Mathieson on February 1, 2008 at 11:28 am
    hi all, how do you download Flash tutorials (like those from videocopilot.net) to hard drive?
    I looked in temp internet files but couldn’t find it
    Austen Mathieson
    Austentatious Productions
    Kevin Chang replied 18 years, 5 months ago 7 Members · 8 Replies
  • 8 Replies
  • Thorsten Miess
    February 1, 2008 at 1:01 pm
    well there is more than 1 way to do it. But what i found is a player wich can download videos (even on youtube) very easily.
    Its called realplayer. Just visit the site http://www.real.com and search for the Real Player and download it. After installing just open the video in your browser and while your going with your mouse over the video a little pop up shout pop up. Just click it and the video will download
  • Steve Roberts
    February 1, 2008 at 2:50 pm
    I just googled “rip” “flash” “video” and found:
    https://www.streamingstar.com/flvrecorder.htm
    Don’t know it, can’t vouch for it.
  • Mike Clasby
    February 1, 2008 at 3:07 pm
    In temporary Internet files, wait until the flv tutorial is fully loaded, then click on the Size column, on top and that will sort the files by size (you might have to click twice, sort small, then large). Copy the large flv and paste into where you want to archive it.
  • Austen Mathieson
    February 1, 2008 at 5:30 pm
    Thanks for replies guys, hi mike, that’s what I tried but there’s no flv file, I even did a full system search for .flv but nothing.
    I’m using xp pro.
    I’ll try again & try those apps.
    Cheers
    Austen Mathieson
  • Tom Edison
    February 1, 2008 at 6:28 pm
    FYI, if you are referring to some of the flash tutorials posted here, they are also available via iTunes as free podcasts. Its great!!!
  • Austen Mathieson
    February 1, 2008 at 6:37 pm
    Thanks Tom I’ll check it out.
    Real player basic works a treat to dl web video I just dl’d 5 tuts in 10 mins.
    Austen Mathieson
  • Joe Moya
    February 1, 2008 at 7:07 pm
    Well… that’s because you need to be in the directory that can be found by following these steps.
    For Internet Explorer 7.0
    Tools>Internet Options>in the General Tap click under Browsing history>Settings>View Files
    You will find the temporary internet files… the flv files WILL be there if you have already gone to the site and watch the video (i.e., they have been downloaded).
    Then copy and paste the file where you want it… you can then view it at any time by opening up that file.
    I do this all the time.
    Joe
  • Kevin Chang
    April 20, 2008 at 6:20 am
    To Save tutorials from videocopilot.net this is what you do:
    Step 1)
    Go to the tutorial (as if you where to watch it) read the source file, find the embed src path…for example “https://video2.videocopilot.net/videotutorials/64-Stabilize_Shaky_Footage/index.swf” copy that.
    Step 2)
    Now paste that into your browser.
    Step 3)
    At the end of that url, delete the “index.swf” replace with “/data/tutorial.flv” – press enter
    Step 4)
    There you go, just save it.
    ps…if you have both the video open on the site and are trying to trigger the download prompt, close the video and then retry, it should pop up real fast. Happy After Effect’ing =)
    .:Kevin:.
