Activity Forums Apple Final Cut Pro Legacy how to dowconvert using kona 3 card?
  • how to dowconvert using kona 3 card?
    Posted by Jamie Nabers on February 4, 2007 at 12:33 am
    Varicam footage shot at 59.94 1280X720 needs to be downconverted for SD broadcast. im told i can downconvert in realtime using the kona 3 card, which i have. how do you do it? and if there are any other downconvert methods, i would love to hear them.
    thanks in advance,
    jamie
    Jamie Nabers replied 19 years, 7 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    February 4, 2007 at 1:27 am
    KOna 3 is an awesome down convert. You need to use the Kona control panel.
    THis is a quote from another thread in the Kona forum that I wrote on 10/20/06
    [JeremyG] “Leave FCP in the HD easy setup. Using the Kona control panel, you can put a down-convert on any output of the kona card at any time. In the control panel select the format tab and change your secondary format to whatever SD standard you are in (525i or 625i). Your primary format should still be whatever HD mode FCP is in. Then select the analog or digital output by clicking it’s icon on the right side of the Control Panel. Change the format from primary to secondary and then you should see a little down-convert icon pop up on the analog pipe.
    It’s a few clicks of a button.”
    Jeremy
  • Walter Biscardi
    February 4, 2007 at 4:20 am
    [jamie] “Varicam footage shot at 59.94 1280X720 needs to be downconverted for SD broadcast. im told i can downconvert in realtime using the kona 3 card, which i have. how do you do it? and if there are any other downconvert methods, i would love to hear them.”
    In the Control Panel. The Kona manual describes the workflow for you.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jamie Nabers
    February 4, 2007 at 6:28 pm
    i have read the manual from cover to cover and searched the posts….. thats why im asking how it works in here. I would just like a description of a real world workflow.
