Activity Forums VEGAS Pro how to do this transition or what is it called?
  • how to do this transition or what is it called?
    Posted by Midhun Mukund on July 15, 2012 at 3:03 pm
    transition from 2:20 to 2:22
    Bruce Brent replied 14 years, 2 months ago 2 Members · 3 Replies
  • Bruce Brent
    July 15, 2012 at 8:09 pm
    Midhun, simple, simple simple…….just delete frames, then skip/leave some frames you want to display, then delete more frames (29.97 frames equal one second, so delete as many frames to show the jump you want to project).
    Another way to show what I mean is to run the clip, stop and delete as many frames you want to remove. Then, run more of the clip you want to show, then stop and delete the next number of frames you want not to show. That way, the action is seen, then deleting frames eliminates the action, then the next set of frames you want to keep shows the resulting action in a new size(zoomed in/out, position, etc.).
    Good luck and keep creating to make your videos fun!
  • Midhun Mukund
    July 15, 2012 at 8:21 pm
    it’s not that jump cut am looking for, in this video (00.36) it goes to the next frame like PLASTIC WRAP, i want to know about that
  • Bruce Brent
    July 15, 2012 at 8:58 pm
    Midhun, at this NEW position you’re talking about, you want the WAVE fx, which is in the “Video FX” tab. Lots of sliders that can change the number if waves, the amplitude of each and positioning of them.
