Activity Forums Apple Final Cut Pro Legacy How To Do This short video?
  • How To Do This short video?
    Posted by Paul Wright on August 28, 2010 at 2:23 pm
    Does anyone recognize what effects or workflow was used to create this video? I’m particularly interested in the large bulletin board look as well as the way the camera moves and shakes in different directions and speeds. Is it Motion? After Effects? iMovie? The moves are nice… FWIW I believe it was done by an intern:
    https://www.youtube.com/watch?v=pTPAuSOAVxM
    Paul
    Bret Williams replied 16 years ago 4 Members · 3 Replies
  • Tom Wolsky
    August 28, 2010 at 3:47 pm
    Either Motion or After Effects can do it.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • John Fishback
    August 28, 2010 at 3:55 pm
    This could be done in Motion or AE. You could make a number of frames, each sized for the delivery frame size, re-size them all to fit inside a “master” frame then simply move the camera zooming in from one frame to the next. Each frame could be its own composition of group.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Bret Williams
    August 28, 2010 at 4:19 pm
    I’m doing something similar in FCP right now, but it’s slower more precise moves. No motion blur is required. I just make a 4000×4000 comp and put a grid-like montage of photos in it, the move it around with Keyframes in the motion tab. You can turn on motion blur in FCP, but it’ll add days to an otherwise 1 hour render. This as probably done in AE the same way or with a camera moving across.
