Activity Forums Adobe After Effects How to do this shine effect (using trapcode) ?
  • How to do this shine effect (using trapcode) ?
    Posted by Jacob Tamari on February 2, 2007 at 9:00 pm
    Hi, this is the image: https://67.59.182.81/yankees/star_demo.jpg
    I’m wondering how to do this shine effect. I need to make the shine of the stars like the image in small on the white of this image (like a cone shape) but when I use trapcode shine the shine goes out instead of going inwards as it continues on…. (like the stars in the black)
    how can I get the shine to go inwards?
    Yankee
    Steve Morris replied 19 years, 7 months ago 3 Members · 2 Replies
  • Steve Roberts
    February 2, 2007 at 10:14 pm
    You can’t use shine for that, since Shine emanates outward from a central point.
    You might want to consider moving the ring of stars from low to high position, then applying the echo filter either to an adjustment layer, or to a rendered movie of that motion. That would give you a set of streaks. I suppose the moving stars would have to be yellow, with a layer of blue stars (non-echoed) comped over top.
    Or you could use Zaxwerks or a 3D app to do an extrusion, or maybe use shatter with a really thick extrusion.
    Anybody else?
  • Steve Morris
    February 2, 2007 at 10:45 pm
    I think Peder has a gobo tutorial on the Trapcode site that looks similar to a single star. You would need to have a separate precomp for each star.
