How to do this key/matte?
Hello
Been trying to do a simple graphic, have a look at
https://www.truthandlife.info/AR.png
which shows at the bottom a psd of an Accident report sheet I want to have simply fade up in place but need to have the Livetype DECKLE 3 matte wrapped around its edges…ie, I need to have the accident report sheet framed “inside” the Deckle 3 matte while maintaining everythig else you see.
The deckle 3 matte has a texture BG, “Aqua” which needs to remain as is…a week or so ago, I got good advice from LT forum saying to use FCP instead of Livetype for this…so I’ve been trying different “composite” modes, to no avail. I’m doing something wrong, and/or I just don’t know how to do this.
On my layer 1 I have BG image, Layer 2 I’ve got the LT Deckle 3 matte with its Aqua BG matte, Layer 3 is the psd of the paper work, layer 4 is the text…
I’ve no idea how to do this. The more specific the better for me if you could please.
Lastly, Should I be using the psd or make it into a png/tiff – does it matter, final delivery will be DVD, shown mostly on PC’s. And how to have it slanted as you see, but not have those awful jagged lines appear, (probably because of interlacing?)
Thanks much
K
