Activity › Forums › Apple Final Cut Pro Legacy › How to do this freeze affect?
Posted by Kent Beeson on July 8, 2010 at 9:11 pmWondered if and how this can be done in FCP 7? Or Motion 4?
https://web.me.com/kbcv/VideoWork/test.htmlThanks
Matt Callac replied 16 years, 1 month ago 3 Members · 11 Replies -
Matt Callac
July 8, 2010 at 9:47 pmIt’s possible to do it in motion…but slightly easier in After Effects. At least I find keyframing masks easier in AE.
Watch this tutorial
https://videocopilot.net/tutorials/time_freeze/Essentially the same concept (multiple times)…only you would have to be masking your moving video layer(s) rather than your freeze frame layers.
-mattyc
Jeremy Garchow
July 9, 2010 at 4:35 pmA similar but different way to do it in Motion:
https://www.youtube.com/watch?v=1ep8392ofGM
Jeremy
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Kent Beeson
July 9, 2010 at 4:50 pmGreat thanks for link – I wonder since my original post’s video is simply shot against an outdoor wall with no transparency, alpha, how would one app this FX? And would one simply reduce the amount of particles to make it match my original post’s video?
K
http://www.effectivevideo.net -
Jeremy Garchow
July 9, 2010 at 4:54 pm[Kent Beeson] “I wonder since my original post’s video is simply shot against an outdoor wall with no transparency, alpha, how would one app this FX?”
Is that shot a lock down or is it handheld? If lockdown, you would simply mask out the guy and composite the FG over the BG, kind of like what the Video Copilot tutorial shows.
[Kent Beeson] “And would one simply reduce the amount of particles to make it match my original post’s video? “
Correct.
Kent Beeson
July 9, 2010 at 8:08 pmThanks for helpful replies, I’ll give it a go reducing the particles and see.
K
Jeremy Garchow
July 9, 2010 at 8:09 pmHave you shot this footage already? If you have a clean plate, (no character in the screen) you can use that for your BG as well.
Jeremy
Kent Beeson
July 9, 2010 at 8:12 pmYou’re right, I haven’t shot yet, I will try to get a clean BG as well…I’ll try just a few particles in MOTION and see…
K
Jeremy Garchow
July 9, 2010 at 8:26 pmYeah, testing is always good. The easiest way to shoot this to lock down the camera, get yourself a clean plate to always fall back on, and then shoot the person moving through the scene without moving the camera so your FG and plate match.
Make sense?
