Activity Forums Adobe After Effects How to do this effects on after effects
  • How to do this effects on after effects
    Posted by Yigit Ersoy on January 13, 2015 at 9:39 pm
    Hi there i would like to ask how can i do this kind of effect on after effects if there is plugin for that please write the name of it. Thanks
    https://www.youtube.com/watch?v=BPiW0tkWfeg
    00:32-00:34 and 00:38-00:40
    Yigit Ersoy replied 11 years, 7 months ago 3 Members · 3 Replies
  • John Cuevas
    January 13, 2015 at 10:02 pm
    Try using the Color Correction “Tint” or “Tritone”(both mid and highlights set to nearly the same color). Then keyframe the “Blend with Original” or “Amount to Tint”.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Daniel Waldron
    January 14, 2015 at 1:20 am
    You’ll also want to use time remapping to freeze the frame where desired.
  • Yigit Ersoy
    January 14, 2015 at 8:31 am
    Thanks a lot, it works great
