Activity Forums Adobe After Effects How to do this effect
  • How to do this effect
    Posted by Johannes Ring on February 27, 2009 at 10:08 am
    Hey guys!
    I’ve been searching tutorials to find a way to do this effect. With no result…
    https://vimeo.com/337298
    In this movie, linked above (awesome by the way!), at 2:19 and forward (when they are dancing), there’s this “light” effect, like in a 3D movie. It seems like a color layer on top, following the movement. It looks really cool I think.
    Does anyone know how to do it?
    /J
    /J
    Mac Pro, Two 2,8 GHz Quad-Core Intel Xeon, 6 GB RAM
    NVIDIA GeForce 8800 GT 512MB
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Johannes Ring replied 17 years, 6 months ago 5 Members · 5 Replies
  • Laurie Gibbs
    February 27, 2009 at 2:54 pm
    Hello,
    One way of achieving this sort of effect is to duplicate your footage twice and to use the tint tool on the top 2 layers of the footage:
    map black to red on one layer and black to green on the other.
    Set their blending modes to Multiply (you could experiment with some others). Apply levels to both layers and decrease the input white values to brighten the footage. Then slightly offset the position of these two layers from your original footage. This should give you your green and red edges.
    Then it is a case of experimenting and fine tuning the effect. I hope this helps.
  • David Bogie
    February 27, 2009 at 3:29 pm
    Look under Channels.
    Could be done as an anaglyph but more likely you just need to move the channels independently. or you can pull a luminance copy of your footage and tint it blue or red and move them separately.
    You sort of play with stuff till you get what you want or can figure out how to keyframe.
    bogiesan
  • Joey Burnham
    February 27, 2009 at 7:10 pm
    Or if you have BCC you can do a BCC Directional Blur on the red and blue channels.
    Joey
  • Kwaku Nyantekyi
    February 28, 2009 at 8:36 pm
    I believe that Ahron Robinowitz did a tutorial on this effect if I’m not mistaken. It’s somewhere in the tutorials section.
  • Johannes Ring
    March 10, 2009 at 10:34 am
    Thank you all for your help!
    /J
