Activity › Forums › Apple Final Cut Pro Legacy › How to do that hip hop music video bounce effect?
Posted by Allthelightsarebroken on September 17, 2007 at 2:39 pmHi, how do you do those bounce effects like in the Hype Williams music videos, usually on the kick drum and the image sort of bounces in and out quickly very smoothly? Been messing about with image size and key frames but its quite crude and the effect I want is supposed to be quite fluid. Is it something like in combustion where you can mess about with the curves in between key frames or is it something else?
Jeremy Garchow replied 19 years ago 6 Members · 10 Replies -
September 17, 2007 at 4:27 pmThis has loads of it…
https://www.youtube.com/watch?v=APHm8DbYkL0&mode=related&search=
The bits where the image bounces like a woofer speaker cone… and some ladies to look at too 🙂
Jeremy Garchow
September 17, 2007 at 4:36 pmDo you have After Effects?
Check out sound keys. Sound keys creates key frames from audio sources that you can then map to different parameters such as scale, rotation, so on and so forth.
Motion 3 might have some of this sort of functionality built in to it, but I haven’t played with it.
Jeremy
Walter Biscardi
September 17, 2007 at 4:44 pm[JeremyG] “Motion 3 might have some of this sort of functionality built in to it, but I haven’t played with it.”
I’m almost certain I saw this demonstrated at NAB, but I haven’t had any use for it so I’m not 100% certain.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Tom Brooks
September 17, 2007 at 8:37 pmI’d just do this in Motion (After Effects, better yet) and animate the scale of the shot. It’s probably best done with good old keyframes. Experiment with the amount of scale increase, the number of times it goes up and down, the speed of the up/down, and the shape of the bezier curves. You have to create the look yourself rather than relying on an actual kickdrum sound to do it, although that could be a starting point. I’m guessing that the scale motion curve will look like a sine wave, but the shape of that wave and how it decays will determine whether it looks to your eye the way the drum sounds to your ear.
Steve Eisen
September 17, 2007 at 11:52 pmThis should give you a start to what you want.
https://www.freshdv.com/2007/08/free-apple-motion-audio-meter-generator.html
Larry Asbell
September 18, 2007 at 2:14 amRather than scale I feel pretty certain that the parameter being animate is something like “Bulge.” Not in front of FCP right now to check the name but the center of the image is popping out more than at the sides. And there’s lots of overshoot.
Tom Brooks
September 18, 2007 at 11:56 amI totally agree with that. The bulging of the center is another trick to make your brain think ‘subwoofer.’
September 18, 2007 at 12:13 pmCool thanks, yea after reading all that I’m thinking of a slight magnify glass effect, using soundkeys on the kick and have a slow exponential curve between key frames on the x/y scale magnify effect (maybe the z?). Either that or maybe I’ll try shooting a tight close up a big speaker cone with a couple of tracker markers. But yes it dose look like its emanating from the center doesn’t it? Just been wondering how to do it, cause someone asked me if i could… and now i just have to know… !
