Activity › Forums › Apple Final Cut Pro Legacy › how to do super fast cuts between two clips?
  • how to do super fast cuts between two clips?
    Posted by Sj Miller on February 10, 2012 at 1:04 pm
    Hi Guys, was wondering if anyone knows of a quick method to do really fast cuts between two clips (aside from frame by frame with the blade tool) in fcpx
    this video has the technique used loads :
    https://www.youtube.com/watch?v=T6j4f8cHBIM
    Eman Weah replied 14 years, 3 months ago 4 Members · 3 Replies
  • Juan Salvo
    February 10, 2012 at 5:28 pm
    In all likelihood that video just did a bunch of edits. One quicker was of doing it is laying one shot over the other and then using the razor tool to cut holes in the shot on top. If you want to do it back on forth in a fixed number of frames you can use the blink filter. You could even keyframe the on/off duration to change the rate of cutting.
  • Jerry Hofmann
    February 10, 2012 at 6:09 pm
    A mulitclip might work, if the timing of the shots would allow for it. That you could cut pretty fast.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Eman Weah
    June 26, 2012 at 6:02 pm
    Please help me….can you show me steps in doing this…my email is:ucpro12@yahoo.com
    Thaks.
