Activity Forums Adobe After Effects how to do polaroid developing effect
  • how to do polaroid developing effect
    Posted by Jeremy Webb on April 22, 2005 at 9:50 pm
    how can i do an effect to make it look like a polaroid is developing”?
    Tom J replied 21 years ago 3 Members · 2 Replies
  • Steve Roberts
    April 22, 2005 at 11:25 pm
    I’d animate the levels or curves effect.
    Steve
  • Tom J
    April 24, 2005 at 5:28 pm
    Another way you can attempt this is to use Fractal noise in an adjustment layer above your target image.
    Quite some time ago I worked on this idea and this is how I stacked my layers:
    1. Polaroid frame (white border mask created in PS w/ alpha, saved as a tif and I applied “Bevel Alpha” to give it some shape in AE)
    2. Mask to isolate the emulsion or photo area (I used a light gray layer color 225 rgb)
    3. Adjustment layer w/ Fractal noise applied (set to “Cloudy”, Noise Type: Soft Linear, Complexity set to 9.0 and Transfer mode set to “screen”)
    4. Source image to be exposed
    I then animated over time to taste the following fractal noise settings:
    Under Sub Settings:
    Sub Influence
    Sub Offset
    Then I animated
    Evolution and Opacity
    Give it a shot, mine turned out pretty convincing from what I recall. If you work on the adj. layer or perhaps the source layer and try other filters you may be able to create a more defined edge as the source is exposed.
    Hope that helps.
    Tom Juliano
    Visual Separation
