Activity › Forums › Adobe After Effects › How to do a lower thirds bar with soft edges
  • How to do a lower thirds bar with soft edges
    Posted by Paul Boone on May 9, 2014 at 1:42 pm
    I just need to make a soft lower thirds bar and my tutorials are from an old version. I’m on a tight deadline. Any quick suggestions?
    John Cuevas replied 12 years, 4 months ago 2 Members · 1 Reply
  • John Cuevas
    May 9, 2014 at 1:48 pm
    Create a solid “cntl + y”, use the rectangle mask tool “Q”(to cycle through mask tools) to create your bar. Press “MF” quickly to open the feather properties and then enter a feather amount. If you unlock the chain, you can adjust the vertical and horizontal feathers separately.
    Add some text, then I would precomp “shift+cntl+c”. Now you can animate both the bar and text together…Position”P”, Opacity”T” or scale”S”. Or you could use an effect like Transition-Linear Wipe to bring them on.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
