Activity › Forums › Adobe After Effects › How to do a face fade in effect?
Posted by Shawn Mall on August 21, 2010 at 9:34 pmFirst off mods, Shawn Mall is my real name, Im not sure why my previous post got deleted.
Anyway
The effect at 2:20
https://www.youtube.com/watch?v=4YTmlcBDhvQ&feature=related
Making the face come from darkness
I need to know how to do it in Sony Vegas or After Effects
Its gonna be made in a game.
Thanks.
Shawn Mall replied 16 years, 1 month ago 3 Members · 4 Replies -
David Johnson
August 22, 2010 at 7:30 pmIf you’re talking about the shot where a guy lights a match that illuminates the frame, that doesn’t look like a post effect (other than one possible composite since it’s doubtful the real Satan is a SAG member, although I’ve known a few with very similar qualities). It’s hard to be sure without being able to frame through, but it seems more likely that was done with precise shooting, lighting and timing, although probably enhanced in post.
Shawn Mall
August 22, 2010 at 10:30 pmThere must be a way to do it in AE though, correct? Im new to AE, so I dont know that much, but maybe some effect that darkens the area, then use keyframe to bring the darkness back, so the face could be shown?
Michael Szalapski
August 23, 2010 at 2:03 pmDoing it during shooting is going to look a lot better, but you can do what you describe in AE. You could use a levels, curves, brightness/contrast, or any other color correction recipe on an adjustment layer (masked so that it’s only over the area you want to change) and then keyframe the opacity of that adjustment layer. Or, if you want to add more detail, you could use something with the Gradient Wipe effect using the layer as the gradient so that the brighter areas pop out first…I dunno, could be fun. Or, possibly you could use a custom (animated) map layer to make it look more realistic.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Shawn Mall
August 23, 2010 at 10:14 pmThank you, i’ll see what i can do. As I said, im still fairly new to AE, but i’ll let everyone know how it goes.
Thanks again.
