Activity Forums Adobe After Effects How to dissolve wall?
  • How to dissolve wall?
    Posted by Tobias Nybom on November 28, 2007 at 8:48 pm
    The scene is from The Little Match Girl. The girl is standing in a narrow alley, late at night. She lights a match and the light from the match falls onto a wall and the lit up area dissolves. Through the wall you see in to a dining room.
    What approach would you recomend?
    Mike Derk replied 18 years, 9 months ago 3 Members · 5 Replies
  • Mike Clasby
    November 29, 2007 at 2:24 am
    Got link?
  • Mike Derk
    November 29, 2007 at 2:30 am
    I would use a mask with a radial gradient to affect the opacity of the wall (and see through to the other side). The detail that I would want to spend the most time on would be the flickering of the matchlight. Maybe wiggle?
  • Tobias Nybom
    November 29, 2007 at 6:38 pm
    Thanks for the tip about wiggle! I
  • Tobias Nybom
    November 29, 2007 at 6:56 pm
    No, you see the scene hasn’t been shot yet. I
  • Mike Derk
    December 3, 2007 at 3:22 pm
    I’m not that expert in AE, so your question is beyond me too.
    However, I would probably never have the wall go to 100% see-through (0% opacity). I would let it hover around 5% (or whatever looks good) so that the texture you apply to the wall to make it look 3D never goes away.
    If you want to remove the wall 100%, and have some texture around the hole, you could use “bevel” (but this would require that: 1) you do your initial effect; 2) you hide the layer with the wall; 3) replace that layer with an identical layer with a hole pre-cut in it, and apply the bevel to that.)
    To be honest, I don’t think it’s necessary since we’re seeing through a wall magically, and not actually putting a hole through the wall.
    Sorry for the late response.
