Activity Forums VEGAS Pro how to display “real” timecode
  • how to display “real” timecode
    Posted by John Baum on July 25, 2005 at 6:54 pm
    Is there a way to display actual timecode overtop the video. Basically the same as if you captured the video through the super channel.
    The timecode effect that comes with vegas only seems to want to start at 00:00:00 and ignores the timeline time if you switch the first frame of your project to something other then o.
    Timothy Duncan replied 21 years, 1 month ago 3 Members · 3 Replies
  • Edward Troxel
    July 25, 2005 at 7:06 pm
    Try adding the timecode effect to that clip in the MEDIA POOL (or Project Media).
    Edward Troxel
    JETDV Scripts
  • John Baum
    July 25, 2005 at 7:52 pm
    when i do this, it is close, but is off by a few seconds. I’ve tried drop and non drop.
  • Timothy Duncan
    July 26, 2005 at 12:49 am
    There’s a script built into Vegas that will turn on TC for all media. Go under “Tools/scripting” to find it. There is one to turn it on and off. This uses the original TC in the clip. If the TC is off, then it was not properly set when captured. When you capture, you have to specify if the TC is drop or non-drop frame. (Most DV camcorders default to DF, and Vegas will default to DF unless you specify otherwise).
    td
