Activity Forums Adobe After Effects How to disable Open GL in after effect CS6? I can’t export a transparent background! (RGB+Alpha)
  • Esther Casas
    April 19, 2013 at 4:21 pm
    oh thta’s very interesting, i never knew the 4th 4 was the alpah channel..good to know! thank you so much again
  • John Cuevas
    April 19, 2013 at 4:55 pm
    I don’t use Apple Pro Res 422, but I understand it does support an alpha channel, so you should be able to render to ProRes. If you need to work in prores, I really can’t offer much help. Perhaps one of the Mac users will stumble in here and lend a hand.
    Sorry about the confusion last night, I was reading the 4444 spec sheet. Glad that you have this worked out now.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
Page 2 of 2
