Activity Forums Apple Final Cut Pro How to disable automatic loading of recently used projects
  • How to disable automatic loading of recently used projects
    Posted by Eric Brodeur on July 3, 2015 at 6:06 pm
    Using FCPX 10.2.1. When I open a Library, Final Cut starts opening recently used projects into my timeline.
    Is there a way to turn this off?
    I’ve looked around for an answer but only found solutions to the old system of Event management.
    Mac OS X 10.5.7 / FCP 6.0.5 / QT 7.62
    15″ MacBook Pro 2.4 GHz / 4 GB / hard disks o’plenty
    Tangier Clarke replied 11 years, 2 months ago 5 Members · 5 Replies
  • Kathy Murphy
    July 3, 2015 at 6:59 pm
    Close the finished project, then it won’t show up.
  • David Gregorio
    July 3, 2015 at 7:03 pm
    You can also hold option key while launching, this allows you to select a specific project or create a new empty library.
    Also comes in handy if a corrupted library is crashing FCPX.
  • Bret Williams
    July 3, 2015 at 7:04 pm
    I don’t think you can close s project. You can close a library, but once you open it it will load a project into the timeline. Seemingly randomly even.
  • Eric Brodeur
    July 13, 2015 at 10:08 pm
    It does appear random. Yesterday it loaded the Library without opening any Projects.
  • Tangier Clarke
    July 17, 2015 at 4:49 pm
    I’ve noticed this as well that randomly FCP X will load a project that I am not working on or referencing. I’ve tried to find something consistent about this behavior, but I can’t and it’s annoying and time consuming.
    You can hold option to force opening a particular library, but that still doesn’t prevent the random loading of projects sometime.
    Tangier
