To create a dithering pattern like you see in those examples, you would want to control the sequence in which grayscale image levels get turned into such a pattern.
You want to create a grid with gray level squares that go from 0 to 100 in a specific order like shown in that example, so that the first dot would be 1/16 of full black, the second one 2/16 etc. Then you can use a combination of mosaic effect on the original footage/image, this grayscale pattern in matching size to the mosaic and blending modes to determine whether a given dot should be black or white.
Kalleheikki Kannisto
Senior Graphic Designer
