Activity Forums DVD Authoring how to determine the make of a dvd player
  • how to determine the make of a dvd player
    Posted by Terry Wilson on September 12, 2010 at 2:16 pm
    The problem i have is pretty simple on the surface, but it’s becoming a real puzzle for me, and I can’t seem to get figure it out.
    I have an options menu with a continuous motion background, the buttons each set a user register (audio, subtitles, etc)
    On certain older dvd players however, there is a bug with the implementation, once you select the button, and it runs the cell command, you cannot move from that position.
    This happens most notably with ps2’s, and ancient dvd players.
    So the solution I’ve come up with is to have two different options menus, one version that sets the register then links the top cell for older players, and one that sets the register then links no link for standard players (so the motion is continuous).
    The problem I now face is, how do I tell the dvd players apart?
    I’ve been thinking that maybe sprm 15 would help me, does anyone know if there was an audio standard that was added in at a later date that i could use to differentiate?
    I’ve also noticed that sometimes there are discrepancies between the way players store sprm 1, sprm 2, sprm 3, sprm 7, sprm 8, and sprm 9, specifically when you pull data from them during pre or post scripting of a pgc just before or after a jump…. Is there anyway I could use this data to my advantage?
    I’ve built a test dvd that outputs the values to take a look, but unfortunately I only have a few dvd players to work with.
    Is there anyone with expertise in this area that could enlighten me?
    Thanks for your help, sorry for the long post.
    Eric Pautsch replied 15 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Eric Pautsch
    September 12, 2010 at 5:18 pm
    Then dont use cell commands. You’re surely not going to find anyone here that knows this data from ages ago. I’d try the Tully List…a great mailing list for DVD professionals.
  • Terry Wilson
    September 12, 2010 at 5:32 pm
    thanks, i’ll check that out.
    I think the only way I’m going to be able to do this is to compile a list of every dvd player i can find.
    sprm 15 is 16 bits, and every player has a different configuration it seems, so i can use that as a bit of a finger print…. maybe i can find a list somewhere……
  • Eric Pautsch
    September 12, 2010 at 6:35 pm
    Also could you be more specific on how some some player implement SPRM differently. SPRM 7 & 8 are pretty critical so if certain brands dont interpret these right, there’s no way to author a disc and get around the discrepancies. Keep your authoring simple I always say.
  • Eric Pautsch
    September 12, 2010 at 6:40 pm
    SPRM 15 just reads whats on the disc. It read what the current audio you have authored. If there’s a player out there that doesnt support any SPRM, you cant help that and its a faulty player, so I wouldn’t be authoring based on faultiness 🙂
  • Noah Kadner
    September 12, 2010 at 7:56 pm
    I would say scale back the design a bit. At the end of the day, yes fancy menus on your DVD are fun to have. But if you create a disc that doesn’t play on a single player because of too complex authoring, you’ve failed don’t you think?
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
  • Bill Stephan
    September 13, 2010 at 11:39 pm
    When you set a GPRM or SPRM value from a menu button, you need to do two things: (1.) Set the desired value into the proper register, and (2.) Jump somewhere else that makes sense (for example, jump to the beginning of the program). It sounds as if you did the first but not the second, especially since a cell command can hold only one command.
    The solution is to jump somewhere you can place more than one command, such as the pre-command area of a dummy PGC.
    You should be able to make this work for almost all DVD players.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Terry Wilson
    September 14, 2010 at 2:49 pm
    no that’s not it, sorry if my post is confusing, that’s not what I’m trying to do. The idea is to have a menu with a motion background that doesn’t reset when you activate a button.
    so the background video begins, the user hits various buttons to set some options, and the background is continuous until the user hits the play button.
    By setting the button command to something like: R(0)=63, this goal is achieved.
    BUT the problem I am having is that on some older dvd players, this will freeze the button navigation, and you will have to hit the menu button on your remote to get back out (which in itself isn’t all that bad, just a nuisance).
    So I’ve set up 2 versions of the menu, one for older dvd players, and one for newer ones. All I have to do is figure out how to differentiate between the two.
    I think I’ve pretty much solved it.
    What I have found in the couple days since my original post is that because SPRM15 is 16 bits (set by the manufacturer), it’s almost like a signature that’s different on every dvd player model,
    what I’m currently looking for is a list of various SPRM 15 values out there for different models.
    Because there are so few players that have this problem all I have to do is check for those signatures, and send any matches to the menu designed for older players
  • Michael Sacci
    September 14, 2010 at 3:45 pm
    [terry wilson] “and you will have to hit the menu button on your remote to get back out (which in itself isn’t all that bad, just a nuisance)”
    Not all that bad, IF you know what to do, must people will find this more than a nuisance.
    [terry wilson] “Because there are so few players”
    How do you know which players have this problem (which is not a problem since you are going against spec, buttons should just somewhere) have you tested every player on the market? How you tested this in every software player with every OS that have been available for the past 15 or so years?
    But this sounds this is more like a personal challenge, which is fine, if you succeed more power to you. This is a lot of effort to make a background video to continue. I hope you are getting paid by the hour to do this.
    But for everyone else out there, author disc as within spec to assure the widest compatibility, you own that much to your client. Creativity needs to take in the boundaries of the format and work with it.
  • Eric Pautsch
    September 14, 2010 at 4:08 pm
    Dude…you’re way out in left field. Are you authoring on Scenarist? When a button is chosen you can set whatever value you want but ultimately the disc needs to go somewhere. Its impossible to set values while a menu’s stream play continuously.
    Whats do you mean by R(0)=63? All that is is giving a value of 63 to GPRM 0. No wonder you have players stopping if thats your only command on a button. I hope none of your clients are reading this thread…ha ha!
    SPRM 15 just defines a player’s audio capabilities. Most are for karaoke functions but the last three bits are for AC3, DTS and PCM. Just about every player supports these 3 audio streams so I guess Im not really sure what your goal is. I appreciate the zeal and all but I think you’re confused. Whatever “signature” you’re looking for simply does not exist…Sorry 🙂
