Activity › Forums › Avid Media Composer › How to delete no needed Luts?
Posted by Tom Knight on October 21, 2017 at 7:26 amHow can I delete Luts, which I do not need, from the window “Color Managment Settings”?
Jimmy See replied 8 years, 10 months ago 3 Members · 3 Replies -
Jimmy See
October 23, 2017 at 6:56 amThe LUTs are installed on a per project basis or shared for all projects on a system. To remove them form the list of available LUTs it should just be a matter of deleting them form the respective LUTs folders from either the shared or project LUT directories.
The shared LUTs are located at
C:\Users\Public\Documents\Shared LUTs
On a windows machine. I don’t know where the equivelant path would be on a mac, however it would be the same directory as the shared Avid projects, which you can have revealed in finder at the project selection stage on opening Avid.
The per-project LUTs I read are given their own directory, in the project directory for a given project. I could not confirm this as I see no such folder in my project, however I don’t have any installed LUTs anyway so it’s probably there.
So it should just be a matter of finding the LUTs in those locations on disk using Finder of Explorer and then deleting them. I would assume the next time you launched Avid they were then absent from the list.
Michael Phillips
October 23, 2017 at 12:42 pmThe previously noted process is how you delete them, but I find it very strange from a design process that the Color Settings window that lets you manage LUTs didn’t include a Delete function.
Michael
