Activity Forums Apple Final Cut Pro Legacy How to delete all media
  • How to delete all media
    Posted by Brecht Wouters on June 16, 2009 at 1:56 pm
    Hi all,
    In Avid, all of the media associated with a project can be deleted with an internal media manager. Is there a tool in FCP which can do that as well? I tried Media Manager, but that only seems to consolidate the media and copy it to someplace else. How do I totally and utterly clear out an entire project after finishing it so no residu is left behind?
    Greets
    Arnie Schlissel replied 17 years, 3 months ago 3 Members · 3 Replies
  • Walter Biscardi
    June 16, 2009 at 2:11 pm
    Go to your Media Drive.
    In the Capture Scratch Folder, Render Files Folder and Audio Renders Folder, throw away the Project folders associated with the project you’re working on.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Brecht Wouters
    June 16, 2009 at 2:24 pm
    Is there an automated way that for instance automatically also deletes images from the documents folder that’a used in the project?
  • Arnie Schlissel
    June 18, 2009 at 4:20 pm
    [Brecht Wouters] “Is there an automated way that for instance automatically also deletes images from the documents folder that’a used in the project?”
    In the browser window you can select all, right click and choose “Make Offline”, then chose “Delete from Disk” (not at a FCP workstation right now, the exact wording may vary), click “OK” at the frightening warning that tells you what you are about to do is ill advised.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
