Activity › Forums › Avid Media Composer › how to delete add edit point?
Posted by Stephen Hockman on September 22, 2005 at 8:22 pmi am on composer. i made an add edit point in my video and audio track. how do i get rid of it?
Will Oswald replied 21 years ago 6 Members · 6 Replies -
Jason
September 23, 2005 at 9:22 pmgo into trim mode and just hit the delete button. works on all video matchframed edits and all audio matchframed edits with no gain changes betwen the two segments.
but if you need to do it across a ton of them then the menu command is the best.j
Will Oswald
September 24, 2005 at 10:59 amI have a slightly similar problem. There tends to build up in the spacer sections of audio tracks lots of unused edits. There appears to be no global remove command. Remove match frames does not work on these as there is no material matched just spacer to spacer splices.
Will O
Carl Amoscato
September 24, 2005 at 3:18 pmHi Will,
Mark an in and out around the area with all the extra edits, and lift it out. I don’t remember which key (not in front of the system right now) but it’s the one with the weightlifter on it.
good luck,
Carl -
Will Oswald
September 24, 2005 at 3:24 pmI was hoping for a global fix otherwise it means around 60 or 70 “lifts” to clear out a rather complex tracklay for a 50 minute film. However thanks for the suggestion and interest.
