Activity › Forums › Adobe After Effects Expressions › How to delete a layer based on its name?
  • How to delete a layer based on its name?
    Posted by Carl Johnson on September 19, 2022 at 6:00 pm
    I am working on a math video and i figured it might be fun to write scripts to allow a visualization of what i explain in the video.
    The short version might be enough to understand where the issue lies. However i go more into details in the Long Version:
    Short Version:
    I want to create an arrow at a point (x1,y1). The arrow is a mask applied to a solid, made using Shape.vertices. I want the base of the arrow (see image) to coincide with the anchor point of the solid, so that i can rotate it without the base moving.
    However, i can’t get that part right. Looks like i can’t understand how Shapes work with respect to the solids.
    Long Version:
    I am designing a vector object following the constructor below:
    The center of the coordinate system is placed at (x1,y1). From there, I draw the vector with coordinates (x,y) by masking the solid to generate an upright arrow of length (base to tip) of sqrt(x^2+y^2) and then i rotate it by the necessary angle to get a vector with coordinate (x,y). To achieve that rotation, i need the anchor point of the solid to coincide with the center of the base of the arrow (like in the drawing).
    I have been unable to place the shape a.
    My end goal: is to be able to animate different vectors, draw grids (that are not necessarily orthogonal), lengthen and add vectors (lengthening by lenghtening the side vertices of the shape).
    I am a mathematician, so the mathematical concepts shouldn’t be the issue here.
    Here is the ugly code:
    //The origin is supposed to be the place on screen where the arrow gets placed.
    function Vector(x,y,origin,r,g,b) {
    this.x = x;
    this.y = y;
    this.angle = -myAngle(x,y);
    this.origin = origin;
    velen = Math.round(length(x,y));
    this.length = velen;
    this.r = r;
    this.g = g;
    this.b = b;
    this.lname = “(” + this.x.toString() + “,” + this.y.toString() + “)”; //So that the name layer matches the coordinates of the vector.
    mySolid = comp.layers.addSolid([r,g,b], this.lname, 2*comp.width , 2*comp.height,1);
    newMask = mySolid.Masks.addProperty(“Mask”);
    Shape = newMask.property(“maskShape”).value;
    this.large = 10; //The arrow base it twice as large
    this.arrowwidth = 7; //
    this. arrowheight = 20;
    Shape.closed = true;
    //The following line is me trying things out :
    Shape.vertices = [2*origin – [this.large,0],2*origin + [this.large,0], 2*origin + [this.large,velen-this.arrowheight], 2*origin + [this.large + this.arrowwidth,velen-this.arrowheight], 2*origin + [0,velen],2*origin + [-this.large – this.arrowwidth,velen-this.arrowheight], 2*origin + [-this.large,velen-this.arrowheight],2*origin – [this.large,0]];
    newMask.property(“maskShape”).setValue(Shape);
    mySolid.property(“rotation”).setValue(this.angle – 90); //This is made so that the vector (100,200) point 100 pixels to the right and 200 up.
    mySolid.property(“position”).setValue(origin);
    //mySolid.anchorPoint.setValue(origin);
    <div>This code works as long as the origin is the middle of the screen, but fails whenever i move the origin (the second image shows what happens when origin = [0,0] and the vector is supposed to be (100,100) (the arrow should be top left of the screen, pointing outside, 100 pixels to the right and 100 up).</div><div>
    I am posting because this is driving me insane.
    </div>
    Carl Johnson replied 4 years ago 2 Members · 3 Replies
  • Andrei Popa
    September 19, 2022 at 7:37 pm
    I think if you move your solid, you should not put the origin in the vertices part. So maybe Shape.vertices should look like this:
    Shape.vertices = [
    - [this.large, 0],
    [this.large, 0],
    [this.large, velen - this.arrowheight],
    [this.large + this.arrowwidth, velen - this.arrowheight],
    [0, velen],
    [-this.large - this.arrowwidth, velen - this.arrowheight],
    [-this.large, velen - this.arrowheight],
    - [this.large, 0]
    But I would not use solid. Why not use shape layer instead? Something like this may work:
    function Vector(x, y, origin, r, g, b) {
    this.x = x;
    this.y = y;
    this.angle = -myAngle(x, y);
    velen = Math.round(length(x, y));
    this.r = r;
    this.g = g;
    this.b = b;
    this.lname = "(" + this.x.toString() + "," + this.y.toString() + ")"; //So that the name layer matches the coordinates of the vector.
    this.arrowheight = 20;
    var myShape = new Shape;
    myShape.closed = true;
    myShape.vertices = [
    - [this.large, 0],
    [this.large, 0],
    [0, velen],
    - [this.large, 0]
    myShapeLayer = createShape(this.lname, myShape);
    myShapeLayer.rotation.setValue(this.angle);
    myShapeLayer.position.setValue(this.origin);
    function createShape(shapeName, shapeValue) {
    var myShape = app.project.activeItem.layers.addShape();
    myShape.name = shapeName;
    var myShapeGroup = myShape.property("ADBE Root Vectors Group");
    var path1 = myShapeGroup.addProperty("ADBE Vector Shape - Group")("ADBE Vector Shape");
    path1.setValue(shapeValue);
    //var myStroke = myShape("Contents").addProperty("ADBE Vector Graphic - Stroke");
    var myFill = myShape("Contents").addProperty("ADBE Vector Graphic - Fill");
    myFill("ADBE Vector Fill Color").setValue([r,g,b]);
    return myShape;
    var myVector = new Vector(12, 12, [0, 0], 1, 1, 1)
    I have tested this without the angle and the length part, as I am missing those functions (I just used square root of the sum of squares for a few tests for length, ignored the angle part).
    Also, as a suggestion. If you do not intend to use your variable outside the function (eg: use myVector.arrowWitdh, myVector.origin etc after declaring myVector) do not declare them with “this.”. That declaration makes them public, and I am not sure you want that.
    LE: What’s up with the thread name? 😀
  • Carl Johnson
    September 20, 2022 at 10:17 am
    Thank you for your answer!
    I fixed my issue Yesterday, but now that i saw your Post, I am implementing it.
    Wome of what you did with the properties is black magic to me.
    I have another question. I want to change lengthen the vector, by changing the shape path.
    So far, i have implemented a button that creates a vector and one that scales it and they work using setValue, as long as they are constant in time. Any suggestion on how i can go at some time, press the scale button and have my vector scaled?
    Somehow i feel like i should use “setValueAtTime()”, but so far haven’t managed to make it work.
    The thread name is my mistake: It was a question i had earlier in the day and i forgot to change it accordingly.
  • Carl Johnson
    September 20, 2022 at 1:45 pm
    Update. I made it work. As an update of what i’ve done so far, the picture shows the result.
    I can place vectors, and animate how they scale through time.
    I realize however now that this project is becoming quite the endeavor.
    Now i need for the objects to keep track of what after effect is doing. So that the properties of my object reflects what it is in after effects. I will probably have to rethink my entire approach. If someone has any vague suggestion of how to achieve that, i’d be thankful. This still was a good exercise.
