Activity Forums Adobe After Effects How to deal with a cameraman reflected in a mirror
  • How to deal with a cameraman reflected in a mirror
    Posted by Calvin Osborne on November 17, 2011 at 12:36 pm
    Hello,
    I am just learning After Effects and was wondering if anyone had a suggestion/technique they would mind sharing for this situation. I am trying to edit some footage that, unfortunately, was shot in a room with a couple of mirrors, and the cameraman keeps getting reflected, on and off, in the mirrors as he is moving around the room. It is only for a few seconds each time, but impossible to deal with by cropping the video. Any suggestions would be appreciated.
    Ben G unguren replied 14 years, 9 months ago 2 Members · 1 Reply
  • Ben G unguren
    November 17, 2011 at 3:28 pm
    Two steps to fix this, one pretty easy, the other pretty complicated:
    Step 1. Create a matte that covers the unwanted reflections. You can do this by making a solid, then applying and animating a mask for those areas. You can also do this with MochaAE, which is generally faster and more accurate, but takes a little longer to figure out the first time.
    Step 2. Create something to put in place of the matte. If there isn’t a lot of detail (blasted-out whiteness, e.g.) this is pretty simple. If you have a lot of detail then you will probably need to create a matte in photoshop that covers the trouble area. If the camera is moving you’ll need to match the movement inside the mirror which means you’ll need to match the movement inside the mirror. You can eyeball this, but it would be better to track it with MochaAE, if you can find enough in that mirror to grab onto.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
