Activity Forums Adobe Illustrator How to cut text from a rectangle with rounded corners?
  • How to cut text from a rectangle with rounded corners?
    Posted by Dave Zane on February 14, 2019 at 11:37 pm
    I need to cut text from a rectangle with rounded corners, allowing the background to show through where the text was. I converted the text using Type>Create Outlines, then removed it from the rectangle behind it using Object>Compound Path>Make. My problem is that the rounded corners property applies to the text cutout… how can I do this and have the text shape be unchanged?
    Kalleheikki Kannisto replied 7 years, 6 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    March 6, 2019 at 10:58 am
    You want to expand appearance to get apply the effect that rounds the rectangle before doing the compound.
    Senior Graphic Designer
