Activity › Forums › Apple Final Cut Pro Legacy › How to “cut” in FCP?
Posted by Frank Muldoon on April 14, 2006 at 7:32 pmIn Avid I can select all tracks, mark in and out, then hit the “X” key to cut out all the material in all tracks.
What is the FCP equivolent? Command X leaves a space.Bret Williams replied 20 years, 5 months ago 6 Members · 12 Replies -
Ben Oliver
April 14, 2006 at 7:35 pmmake your cuts, highlight them, and hit delete, the one on top of the arrow keyes, it’ll cut out the material and scoot your timeline down to the first point.
Bret Williams
April 14, 2006 at 7:36 pmCmd+x is a “cut” much in the sense of copy and paste. You’ve now put that selection on the clipboard. In FCP the comand you’re looking for would be delete (lift) or shift+delete (cut).
Bret Williams
April 14, 2006 at 7:38 pmOr that. FCP calls it ripple delete. The delete key under F11/F12 is the lift key and holding shift makes it the ripple delete key.
Bret Williams
April 14, 2006 at 7:52 pmI just looked at the menu and it lists these functions under sequence. ????
The actually call it lift and ripple delete these days. But they show the icon for the delete key over the numbers for lift. Actually, it’s pointed the other way, I guess meaning the delete key over under the f11/f12, but that key doesn’t say anything except “delete.” Very freakin confusing if you’re trying to learn.
They might put them under the edit menu as well, since that’s what you’re doing. Editing!
Kevin Monahan
April 14, 2006 at 8:16 pmThe “del” key under the HELP button will also do a ripple delete.
BTW, I always wondered why Apple changed “Delete” to “Lift” while they didn’t change “Ripple Delete” to “Extract”. 😉
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com -
Misha Aranyshev
April 14, 2006 at 9:16 pmCommand-Shift-X ripple-cuts. Command-Shift-V inserts (ripple pastes). Delete (Backspace) leaves the gap, Shift-Delete closes. There is a consistency.
Tom Wolsky
April 14, 2006 at 9:27 pmYou don’t need the Cmd key. Shift-X ripple cuts. Shift-V ripple pastes.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
