Activity Forums Maxon Cinema 4D How to curve an object after extruding it from a vector?
  • How to curve an object after extruding it from a vector?
    Posted by James Pierson on August 6, 2013 at 10:02 am
    Hello,
    I am as new as you can get to Cinema 4D, so I apologise if I use the wrong terminology. But basically I drew a simple ‘trophy cup’ in illustrator, from there I then imported it into Cinema 4D, used the extrude NURBS button and linked my illustrator lines, played around with the depth/positioning of everything until I was happy with it.
    I’ve attached a screen shot:
    The problem i’m having is essentially the cup I have is just a flat image with depth, I would like to be able to have the body of the cup curved like it would be in real life (the top of the cup a circle rather then a rectangle, and coming in at the middle in a nice curve etc.) I converted the body of the cup to an editable nurb, but I have no idea where to begin shaping/curving it.
    Any help would be hugely appreciated!
    Kind regards,
    James
    James Pierson replied 13 years, 1 month ago 3 Members · 3 Replies
  • Dan Conrad
    August 6, 2013 at 1:46 pm
    The “cup” should be modeled used a LatheNurbs and a spline… but in your setup you could try adding a bulge deformer and see what you get. You’ll have to subdived your geometry on the face as it looks like one N-gon.
    http://www.mographcandy.com
    Twitter: @mographcandy
  • Brian Jones
    August 6, 2013 at 2:43 pm
    take the spline you are extruding and put it into a LatheNurb rather than the extrudenurb. You really only need half the spline with a lathe as it spins the spline 360° around.
  • James Pierson
    August 6, 2013 at 3:14 pm
    Thanks so much guys, I did what you suggested and drew a spline, then used the lathe extruder – worked perfectly.
    Thanks again!
    James
