Activity Forums Adobe Premiere Pro how to create wave like effects
    September 13, 2025 at 9:05 pm
    Hey Fahim,
    A quick search on Google came up with this 1 minute video on how to do it:
    https://youtu.be/f9LmmlvfGTU?si=9LZP2c7428XwT-iK
    Hope that this works for you.
  • Fahim siyam
    September 13, 2025 at 9:12 pm
    i try this did not give the desired result even after many tweakings. have to try something else
    September 13, 2025 at 9:21 pm
    Hey Fahim,
    Not to sound discourteous, but you need to think outside the box, and to do that you need to learn the software in depth. Setting yourself a task like this one, will challenge you.
    But don’t give up!
    Did you add an adjustment layer above the video and added the effect to the adjustment layer?
    The you can spin and turn the effect, without the video itself moving.
    Or maybe head over to After Effects, and do it there, as you have more possibilities + use of Expressions.
  • Fahim siyam
    September 13, 2025 at 9:32 pm
    i will try that , 👍
  • Fahim siyam
    September 13, 2025 at 9:40 pm
    Done and Dusted. The idea of using adjustment layer definitely helped. Thank you very much sir. wish i had teachers like you at school.
    September 13, 2025 at 9:58 pm
    Looking good.
    Well Done!
    Happy to help.
  • Brie Clayton
    September 13, 2025 at 11:27 pm
    Thanks for solving this one, Mads!
