Activity › Forums › Adobe After Effects › How to create Videodrome effect
  • How to create Videodrome effect
    Posted by Ponyack on June 18, 2005 at 11:01 pm
    i was wondering if anyone knew of a way to recreate the hand coming outof the tv fromthe movie video drome. any help would be appreciated
    thanks
    ponyack
    Aharon Rabinowitz replied 21 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Danny Perez-triana
    June 18, 2005 at 11:56 pm
    i know from watching the “making of” on the dvd, that that effect was effect by rear-projecting onto a sheet of latex that doubled as the screen. Then someone just stuck their hand through the hollow body of the tv and pushed out on the latex. this probably doesn’t help you in terms of how to accomplish this digitally, but an interesting fact nonetheless.
    good luck,
    ignacio
  • Aharon Rabinowitz
    June 19, 2005 at 1:56 am
    If you did it with a 3D program, you could make the TV Screen a “Cloth” either in maya or Max or whatever 3D program you use, and then model a 3D hand and have it push up agains the cloth and deform it.
    I don;t think you can pull this off in just AE.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Mike Clasby
    June 19, 2005 at 5:40 am
    Me thinks, Digital Anarchy’s 3D layer should do it with the proper Grayscale displacement map.
    https://www.digitalanarchy.com/3Dlayer/3Dlayer_main.html
  • Ponyack
    June 19, 2005 at 8:16 am
    yikesmikes to the rescue once agian…that should do the trick. i been trying something using wave world and caustics…not the desired result but now i have a new animation
    thanks
    ponyack
  • Graham Quince
    June 20, 2005 at 2:12 pm
    Could you use 3d layer to reproduce the Stargate gate effects, where a cg water splash opens the wormhole? Obviously the stargate crew used a high-end program, but i’d be curious to know if it could be reproduced
    Graham
  • Aharon Rabinowitz
    June 20, 2005 at 2:40 pm
    Hate to break it to you, they went lo tech for that, if I’m not mistaken.
    The filmed a water tank and blasted air (or water?) into it and filmed it from several directions. In fact, if you watch the series or movie, you’ll see that they only show it head on or from the side – otherwise it would get distorted if shot at a 3/4 angle.
    You can probably recreate something similar with particle Illusion at https://www.wondertouch.com. We have a forum for that program here as well.
    Aharon Rabinowitz
  • Graham Quince
    June 21, 2005 at 8:09 am
    Lo-tech? Wow, looks good.
    Oh well, i’ve got Particle Illusion but must admit i’ve not been able to reproduce it. I’m not making a film or anything, but shows like Stargate are always giving me ideas to see if i can reproduce.
    Thanks Aharon
  • Aharon Rabinowitz
    June 21, 2005 at 12:00 pm
    Post the Q in the pIllusion forum. While I’ve never tried it, I know others have, so give it a shot.
    Aharon Rabinowitz
