Activity Forums Adobe Premiere Pro How to create two synced video pieces to be played on separate screens?
  • How to create two synced video pieces to be played on separate screens?
    Posted by Adi Frank on April 15, 2016 at 5:29 pm
    Hi. I want to edit two video pieces that will ultimately be screened simultaneously — each on a separate screen — however, they are timed and should be in sync with one another.
    How is it possible to go about doing this? Can I do this with Adobe Premiere?
    And, how would I go about playing this type of video? Is it possible to create one file with two channels of video where one goes to one monitor and the other channel goes to a 2nd monitor, or something like that?
    Pierpaolo Ferlaino replied 10 years, 4 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    April 15, 2016 at 5:42 pm
    [adi head] “And, how would I go about playing this type of video?”
    It really depends on the hardware/software solution that’s running the thing. Usually you have different files exported for different screens and the player will play them in sync on their respective projectors/monitors/whatever.
  • Adi Frank
    April 15, 2016 at 5:48 pm
    @Tero
    Thanks for the reply!
    So what I’m understanding is —
    1. Edit each on a different track in Premiere
    2. Then render each of them as separate files
    3. Find a certain type of player that is able to play two files simultaneously in sync to two different monitors
    Correct?
    Regarding the playback of the files, I don’t have any hard/software at the moment. This will be a video piece in an art exhibition. I’m assuming I’ll be able to request whatever hardware or software is necessary, as long as it fits our budget.
  • Pierpaolo Ferlaino
    April 16, 2016 at 4:46 pm
    I often edited videos for synced screens and I have different approaches depending on the project but I either use a single timeline and edit each screen on a separate track (then I render each of them in a separate file) or I use stacked timelines (or so called “pancake timelines”)
    The playback system really depends on the budget and the goal of your projections… There are a lot of software and hardware solutions out there…
    Just note, for you exports, that multi screen syncing usually works better with CBR encoded files rather than VBR…
