Activity › Forums › Adobe After Effects › How to create this weather map effect
  • How to create this weather map effect
    Posted by ria clarke on April 7, 2023 at 12:53 am
    This might be a bit of an ask but does anyone know how to create this effect? It needs to morph as the map changes.
    I’ve used separate shapes with a choke and it does make the shapes seem like theyre morphing but i need the center colours to mix together without the stroke colour
    You can see in mine the center two reds dont merge where they overlay but the outlines will
    any help would be amazing!!
    Graham Quince replied 3 years, 5 months ago 2 Members · 1 Reply
  • Graham Quince
    April 7, 2023 at 1:25 pm
    To get those colours, take a look at Colorama, I used it in a similar fashion at 2:30 into my doppler weather radar video:
    https://youtu.be/3l71RR3_DIo?t=146
    To work, you only use a gradient between black and white and your second shape should use a transfer mode so that the colours blend together. Place Colorama on an adjustment layer and it should get you the effect you’re after.
