Activity › Forums › Adobe Photoshop › How to create this type of effect
  • Theo Van laar
    October 23, 2009 at 11:06 am
    Do you mean like this?
    Theo
  • Kishore Kumar
    October 23, 2009 at 4:13 pm
    Dear Sir,
    Thanks for the reply. I need help on the text effect on the image. like what type of effect used to create the text with light effect.
  • Theo Van laar
    October 23, 2009 at 8:03 pm
    Do you mean this?
    Theo
  • Peter Greenstone
    October 23, 2009 at 11:40 pm
    Please have the courtesy of providing some sort of details in your question. There are all sorts of things going on in that image. There are reflections, shadows, beveling, lighting, and other things all in there.
    What exactly do you want to know how to do?
    https://www.petergreenstone.com
  • Kishore Kumar
    October 24, 2009 at 9:01 am
    Sir,
    Thanks, this is what i need. Please tell me how you created the light effect
  • Theo Van laar
    October 24, 2009 at 2:55 pm
    The light spot on the black background was made with the GRADIENT TOOL directly on the background layer, using the radial gradient from gray to transparant.
    The shadows behind the text was made with the layerstyle tool that you will find at the bottom of the layers tab (see the picture in my previous reply).
    The light effect on the text was made by adding a mask to the text layer (see the picture in the previous reply. You find the ADD MASK button also at the bottom of the layers tab. Then by applying a linear black to white gradient to the mask (make sure you select the mask first!), the light effect can be simulated. Just play with the place, direction and the length of the gradient and see that you can make it exactly as you like.
    Theo
