Activity Forums Adobe After Effects How to create this pixelation look
  • How to create this pixelation look
    Posted by Chandra on April 8, 2012 at 1:18 am
    Hi there,
    So I was wondering if there is quick trick I am unaware of to create this beautiful pixelation look.
    I know to use a mosaic plugin (I have BCC moasic and all the standards) But I can’t figure out how to do the transitions, wipes and random movements seen in these two videos. I know it has to be easy and I must just not be thinking clearly lol. I figured I would just do some creative masking, but I feel like there might be something simpler I am missing. I love the jumpy quick feel of this.
    Any suggestions?? I did some searches on line and here for “pixelation look” and other things, nothing has come up so far.
    thanks for any great advice!!!
    Video inspiration:
    https://vimeo.com/38095108
    https://vimeo.com/38052583
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Chandra replied 14 years, 5 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    April 8, 2012 at 1:34 am
    Looks like it’s a precomposed video file that is being pixelated. The second example really points to the fact that there is the face of the person playing under the pixelation. The first one may be the same thing but fed a random texture that is being altered by the wiggle command (AE has some generators like gradient, noise, etc you can use for this).
    It also looks like they’re wiggling the opacity of the pixelation as a whole which gives it some “movement”.
    It’s a combination of a lot of little things.
  • Chandra
    April 8, 2012 at 1:38 am
    Thanks for the response! I appreciate it!
    Ya, I have been playing with moving video and Moasic and cell pattern. Still can’t get those cool quick transitions though. Like the very first few frames.
    I think by getting some animated video and doing some masking and animation in one comp, then bringing into a second comp and adding the mosaic onto that will give a cool look. lots of possibilities, just wondering if anyone has done this and had some brilliant advice 🙂
    I will keep playing! All advice is welcome!!! 🙂
  • Erik Waluska
    April 8, 2012 at 3:55 pm
    I think you’re on the right track and I believe the transitions may just be a modified animation preset. Go to Animation>Browse Presets and when Bridge opens go to “Transistions – Dissolves and look at the “Block Dissolve – Random” preset. Double-click it to add it to the selected layer in AE. It has some options for block size and you can adjust the keyframes to get the speed you want.
  • Chandra
    April 9, 2012 at 12:59 am
    haha,Thanks! I knew it was something ridiculously easy! 🙂 Ive got it all worked out now! Yay 🙂 Thanks for the help!!!
