Activity Forums Adobe After Effects How to create this opening sequence?
  • How to create this opening sequence?
    Posted by Soham Jani on April 22, 2016 at 9:41 pm
    Is there a way to re-create the opening of this video, from where the jet fuel of the plane turns into the video?
    https://youtu.be/SDe1xi4tGUA
    \”It\’s all around us Neo, temporary constructs of time…..\”
    Jon Simpson replied 10 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    April 22, 2016 at 11:50 pm
    if you’re talking about the 4 or 5 second mark where the shot shatters like glass, then I think you could try the shatter effect, setting the shape pattern to glass to get started with.
    and then cc pixel poly on another layer to create the finer particles (or shatter, with higher shape repetitions, or another particle system)
    with shatter, you can also create your own shatter map to get glass shards more like the example. you should be abel to find several tutorials on that.
    you’ll need to finesse that more, but I think you can get close.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Jon Simpson
    April 25, 2016 at 12:11 am
    This looks like a combination of a 3rd party plugin and AE effects.
