Activity › Forums › Apple Final Cut Pro › How to create this effect in FCPX?
  • Eric Santiago
    September 2, 2021 at 12:30 pm
    Looks like CG.
    Not sure if that’s possible to produce within FCPX.
    Maybe to edit it together that’s about it.
  • Doug Metz
    September 2, 2021 at 9:30 pm
    Judging by the ‘floating’ emblem, it looks like there’s a second instance of the original video stacked on top, with a shape mask applied to the emblem on the upper copy. It was probably then keyframed for scale and offset, and back again. Additional mask on the original around the emblem to bring the opacity / brightness down so it’s in ‘shadow’. Shouldn’t be too difficult.
  • Mark Suszko
    September 7, 2021 at 7:27 pm
    I wouldn’t do it in FCPX, but rather in Apple Motion, then import to FCPX.
    There’s third-party products from Motion VFX that will let you make and import CGI objects into Motion and FCPX.
