Activity › Forums › Adobe Photoshop › How to create this block letter effect?
Posted by Devon Lee on June 27, 2011 at 12:20 amJaime Montaño replied 15 years, 2 months ago 3 Members · 2 Replies -
Scott Valentine
July 2, 2011 at 7:13 pmWhat version of PS do you have? In CS5 Extended, you’d do this with the Repoussé tool and simply extrude the text, using a scaling effect along with a short lens to get the appearance of depth.
I haven’t done this in AI in long enough that I couldn’t tell you right off the bat.
Jaime Montaño
July 5, 2011 at 6:02 pmI hope to be clear enough.
– Create your text layer and duplicate it. Work in hires.
– Decrease size and align both to center.
– Reduce opacity of both at 50% so you can see behind.
– Using the pen tool conect the dots between both and create shapes.
– Add a bit of shading via soft brush and there you have it.I’ve done this in 5 minutes.
