Activity Forums Adobe After Effects How to create this animation?
  • How to create this animation?
    Posted by Faisal Maniar on March 1, 2021 at 4:03 pm
    Hi, cows!
    Need help with animation. Please check out this video ( 1st 6 seconds only) –> https://youtu.be/dre9jCYRWYw
    In the 1st 6 seconds, the two small circles with icons revolve around the large circle. They change shape while moving and then take the original shape of the circle on the next stop.
    I want to recreate that revolving animation of circles while changing shapes. I was able to revolve them around the circle by tracing the path. I don’t know how to change their shape while they move.
    The animation is quick so watch the video at 0.5x to observe the motion I am talking about.
    Please help me out.
    Faisal Maniar replied 5 years, 6 months ago 3 Members · 5 Replies
  • Eric Santiago
    March 1, 2021 at 4:07 pm
    There is a plug-in at aescripts for that effect.
    By hand, its an organic style animated vector shape.
    For beginners start with the bouncing ball technique.
    Then move up to the organic style animation.
  • Faisal Maniar
    March 2, 2021 at 4:59 pm
    Thank you, Eric. I am comfortable with the bouncing ball technique.
    I am interested in that particular effect right now. I was able to create a similar-looking effect by applying the twist operator to the circle shape. However, it’s not perfect.
  • Eric Santiago
    March 3, 2021 at 1:47 pm
    It’s more of a morphing technique.
    Where it starts as an ellipse then into a pill shape with a bend.
    Some would keyframe that but I am sure there are combinations of distorted options that can do it.
    Just need to practice.
  • Robert Müller
    March 4, 2021 at 9:50 am
    I would go a different direction. I would create a big circle around the central one, give it a big stroke matching the diameter of the small outer circle I want to create and make sure the stroke has rounded caps. Then I add a trim path where the start or the end (depending on the direction I want the circle to spin) are very close, so lets say start at 0% and end at 0.1%. The resulting stroked path should appear as a circle. Now I would animate the offste of the trim path, animate the start/end property so the stroke stretches and shortens again and finally I would edit the stroke thickness so it appears to be shrinking while moving.
  • Faisal Maniar
    March 5, 2021 at 7:20 am
    Wow, Robert! Thank you so much. I knew this would work as soon as I read it. I went in and tried it. I am able to create the exact effect.
    Until now I was thinking, I need to do some kind of morphing technique to produce this as Eric also suggested. But this is so easy. Thank you once again.
