Activity Forums Adobe After Effects how to create thih effect?
  • John Cuevas
    August 31, 2010 at 5:31 pm
    Probably get better answers in the Cinematography forums but I believe in the first example, they used a special stedicam rig that attaches to the talent and points at himself.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • Ivan Minic
    August 31, 2010 at 5:45 pm
    in the second video camera rotates with the singer when it’s in black-white and it also follow the beer flask later
  • John Cuevas
    August 31, 2010 at 6:07 pm
    The technique in the first one uses what’s called a “SnorriCam”
    https://en.wikipedia.org/wiki/SnorriCam
  • Philippe Lessard
    August 31, 2010 at 7:00 pm
    You can achieve a look like this just by stabilizing your shot around the element you want to be steady.You’ll have to shot more wide then you want your final frame, because when you stabilize, the frame move to keep the element you chose in the center.Mocha for after effect is the tool you want for this.Check on there website for a tutorial on image stabilization.
    https://www.imagineersystems.com
    Hope this help.
  • Ivan Minic
    August 31, 2010 at 11:37 pm
    thx youre greatest!!!!
  • Ivan Minic
    September 1, 2010 at 10:18 am
    and what about part when the girl is dancing shot from above and camera follow her hips
    also mocha?
