Activity Forums Adobe After Effects How to create shiny Force field effect
  • Randy Mcwilson
    November 19, 2007 at 9:55 pm
    Thanks. Im working on it now. How do I make the top only show the front, and the bottom sphere only show the back?
    Randy
  • Randy Mcwilson
    November 24, 2007 at 4:03 am
    Here is what I came up with. Not perfect, but it has possibilities. It is easy to customize where the Force field intersects the ground by manipulating 2 masks, on clearly labeled layers. The comps are labeled as well.
    https://defendyourfaith.com/After-Effects/Force-field.aep
    Hope this is of some use!
    -Randy
