Activity › Forums › Adobe After Effects › How to create radial stripes in AE ?
  • How to create radial stripes in AE ?
    Posted by Diego Massanti on May 18, 2009 at 5:28 am
    Hi there, i was wondering what is the best technique to create radial animated stripes in AE like the ones on this video:
    https://www.youtube.com/watch?v=3xGsqRAtoqQ (FF to 00:50) to see them.
    I can certainly imagine some ways to do this, but i was wondering about what’s the best way to get the same effect.
    Any suggestion / idea is welcome.
    Cheers.
    Diego Massanti.
    Diego Massanti replied 17 years, 4 months ago 2 Members · 5 Replies
  • Kevin Camp
    May 18, 2009 at 3:29 pm
    the radio waves effect will create the radiating circles fairly easily. a few different layers with different rate of expansion and line thicknesses may get you close. it also looks like a distortion effect like bulge or spherize may have been used to create the distortion at the edges.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    May 18, 2009 at 4:13 pm
    cc sphere would do a nicer job, but you could fake that and do it all on one layer….
    add the radio waves effect (for starters, increase the start and end widths for the stroke). add the spherize effect, then add the circle effect. set the circle effect’s blending mode property to ‘stencil alpha’ to use the circle as a mask.
    enable expressions for the radius and center of the circle effect and use the expression pickwhip to link those properties to the same properties of the spherize effect.
    now as you manipulate the center and radius of the spherize effect, you’ll create something that looks fairly similar to circles radiating around a sphere… though it won’t be as real looking as cc sphere, it should be a bit easier to manipulate.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Diego Massanti
    May 18, 2009 at 4:20 pm
    Hey Kevin, thanks a lot for the radio waves tip!, thats the kind of plugin that I always see but never took the time to try…
    I did some simple tests and it seems to be what i was looking for so far.
    Regarding the CC Sphere one, i cant really figure out how to make the striped looking with it…. maybe i am missing something ? or where you suggesting to use the CC Sphere for a different thing ?
    Thanks again, Diego.
    Cheers.
    Diego Massanti.
  • Kevin Camp
    May 18, 2009 at 5:04 pm
    to use cc sphere, you’ll first want to create you animated texture in another comp.
    make that comp 2x’s as wides as tall (maybe 1000×500). add a solid that is that comp’s width, but only 50 or so pixels high (this will be the thickness on the radiating circle) and animate the position top to bottom.
    bring that comp into a new (normal sized) comp and add the cc sphere effect to it. rotate the sphere around a bit and do a ram preview and the line should animate like a radiating circle from the top pole of the sphere to the bottom pole.
    you can further adjust the sphere render from ‘full’ to ‘outside’ surface and set shading ambient light to 100 to make it ‘flat’ rather than shaded like a sphere.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Diego Massanti
    May 18, 2009 at 6:53 pm
    Ok Kevin, thanks again for your really helpful answer. I see now why i wasn’t understanding the sphere thing :p
    The reason is that i wasn’t trying to recreate the globes (planets) things on that video, i was only interested in the animated curved stripes, but in any case your tip is more than welcome and yes, using spherize and circle as you suggested allows you to create a really nice striped globe!
    Cheers.
    Diego Massanti.
