Activity › Forums › Adobe Premiere Pro › How to create new sequence in open bin, not in project pane.
  • How to create new sequence in open bin, not in project pane.
    Posted by Joy E reed on December 20, 2017 at 3:16 pm
    I feel like I must be missing something obvious and I’m counting on y’all to point it out.
    When I create a new sequence, it appears in the project pane. Even if I have the bin open that I want the sequence to go into, and the last place I clicked was inside that bin, the new sequence is always in the project pane, not inside a bin.
    This happens if I right click inside the open bin to create the new sequence, and it happens if I use the new item button at the bottom of the open bin. Is there any way to insure that a new sequence is created in the desired bin without having to drag it in from the project pane? What am I missing?
    Thanks in advance for your time, CCrs.
    Peace & respect,
    Joy E. Reed
    http://www.ohmyproductions.net
    Todd Perchert replied 8 years, 9 months ago 2 Members · 3 Replies
  • Todd Perchert
    December 20, 2017 at 3:54 pm
    If you have your bin selected, it will create the new sequence in that bin.
    TC
  • Joy E reed
    December 20, 2017 at 10:16 pm
    Thanks, for chiming in, Todd.
    So that means I can’t have the bin open in its own pane and click within it, but I have to click back to the project pane anyway, select the desired bin, and then I can create the sequence inside the bin? I suppose it’s one fewer steps than I’ve been doing.????
    Peace & respect,
    Joy E. Reed
  • Todd Perchert
    December 20, 2017 at 11:23 pm
    Gotcha.Yeah, I twirl open my bins, which works in creating a new sequence into a bin. Looks like it doesn’t do that with a bin open in it’s own pane. Seems it should work that way. Might be a request to Adobe to get that.
    TC
